HELP!!! Flood damage
Old Oct 24, 2018 | 09:36 PM
Jeffrey Smith's Avatar
Jeffrey Smith
Default HELP!!! Flood damage
My 1999 1500 5.9l ram was submerged up to the windshield in flood water. I can't get it to fire now.
I have completely gutted the interior and removed carpet, dried seats cleaned all mud and leftover water, checked wiring, cleaned connections, and dash components.
As for the motor I pulled the plugs, drained water from cylinder heads and intake manifold, changed oil and filter, dropped fuel tank, pulled and cleaned injectors, replaced fuses and relays, pulled distributor and cleaned rotor button and replaced dist cap, and swapped computers (mainly due to the fact that it was for a 5.2 not a 5.9).
I verified fuel squirting from injectors, verified spark, motor spins not locked. Just won't fire!! I have gone thru with a fine toothed wire brush and carb cleaner. What am I missing??
Old Oct 25, 2018 | 07:50 AM
If you have spark, and fuel, it *should* run....... Does the engine sound normal when cranking?
Old Oct 25, 2018 | 04:25 PM
Jeffrey Smith
it sounds normal. I have spark coming from the top of the coil pack.
Old Oct 25, 2018 | 05:58 PM
Hhhmmmm..... So it's either too much fuel, or not enough. Got a scanner you can plug in, and read data?
Old Oct 25, 2018 | 06:34 PM
Jeffrey Smith
Just an obd2. it does real time but not too many sensors read
Old Oct 25, 2018 | 08:05 PM
cruzer55's Avatar
cruzer55
I would check on another computer. Just a thought................
Old Nov 2, 2018 | 08:20 AM
Jeffrey Smith
I purchased a new one. It turns and tris to start but sounds like it's 180 out but I haven't move the timing at all.
Old Nov 2, 2018 | 09:47 AM
Check compression.
