LED shows 4 wheel drive but it really isn't
Old Nov 13, 2018 | 09:48 PM
cnt1973's Avatar
cnt1973
Default LED shows 4 wheel drive but it really isn't
So with the winter coming upon us I thought I should make sure my 4 wheel drive is working in my 2005 Dodge Ram SLT with 5,7 hemi. I had the truck in park and turned the switch. It shows it was in 4 wheel drive but for some odd reason when I turned I noticed it really was not in 4 wheel drive. So I put the truck up in the air so all 4 tired where up and started the truck with 4 wheel drive engaged. The front axle is moving but the half shafts are not moving from the front transfer case. So is the front transfer case done for? I don't hear any grinding of gears in the front transfer case. I am just little puzzled...
Old Nov 14, 2018 | 09:25 AM
What year is your truck? 1500? 2500? 3500?
Old Nov 14, 2018 | 08:07 PM
cnt1973's Avatar
cnt1973
2005 1500 slt
Old Nov 15, 2018 | 08:28 AM
Is there a disconnect on one of the axles in front? If not, then the front diff has some issues.
Old Nov 15, 2018 | 10:15 AM
cnt1973's Avatar
cnt1973
No disconnect... I was thinking the same thing about front diff has issues. I might pull the cover off next weekend and see what I find and take pictures then update the thread.
Old Nov 15, 2018 | 07:40 PM
If it doesn't make any rude noises...... wonder if the previous owner just removed some parts from it....
Old Nov 15, 2018 | 08:56 PM
cnt1973's Avatar
cnt1973
It worked fine over the past five years. I just noticed other day it was not engaging but the led light showed that it is ans the dash says it is.
Old Nov 16, 2018 | 09:17 AM
That's just bizarre. Jack up the front, (leave it in 2wd) and turn the front driveshaft by hand. See if anything obvious presents itself. I would suspect something broke, but, I would expect something broken to make all sorts of rude noises as well.....
