Burning oil after changing to Blend
Hey Guys,
It seems both of my vehicles are burning oil suddenly after a few rounds of Valvoline Max Life. My truck is 06 Dodge with Hemi, I have had it since new, currently at 205,000 miles, and the last few actual oil changes have shown consumption, then the last couple times I was due for a change, I didn't have time, but checked the level and needed almost 2 qts (of 7.5) qts so I just topped it off and called it good enough for a change for now. I've been using Max Life since about 175,000, before that was bulk oil from dealership which I was told was manufactured by Valvoline at that time, when it switch to Pennzoil, I switched to Max Life, cuz I've always been a fan of Valvoline oil. My Wife's 05 Jeep with a Hemi has 186,000 and I used Max Life the whole time we've had it, which was about 140-150,000, and seems to be consuming now as well, as I've done the same thing for the last few needed oil changes, just topped it off with 1-2 qts.
I was just wondering if this is likely coincidental, or if the Max Life actually did something that may have caused this consumption, and if there is a way to possibly correct it, or if I just have to grit and bear it.
I posted this on another site and got mostly smart alec answers about the frequency I check the oil. But I did get a couple good suggestions about switching back to conventional. I have since changed the oil to conventional Valvoline so we will wait and see, I just wanted some more opinions to the specific motor from you guys, and to ask another part of the question. I noticed the price of conventional has gone up signifcantly, is the same as blended, and if blended is on sale it's actually cheaper than conventional. Since I am having issues seemingly with blended, and the cost of Full synthetic has dropped quite a bit, would it be wise to switch to Full syn instead of conventional??
Thank You in Advance,
Eric
Eric
So far as I know, the Max Life oil IS 'standard' oil, just some additional cleaning additives for those high mileage motors.
Do you see any smoke at startup? Or when you are hard on the throttle? At that mileage, it probably wouldn't hurt to do valve seals. Not really that bad of a job, just time-consuming.
I have been using valvoline blend oil for a long time. No oil consumption issues with it. I would recommend replacing your pcv valve. With around 200k miles i would recommend doing a tune up. If you have plenty of down time i would pull your plugs out and pore in some marvel oil or a product you believe in to let the rings soak in. Ive seen more then a few motors with gunked up oil rings that where not doing there job anymore with 150k to 200k miles. Valve stem seals would also be a likely cause of oil consumption. Inspecting your plugs would help tell you if its burning oil, could be an oil leak so also check around your oil pan, valve covers and front and rear main seal.
HMG81, many old-school auto engine maintainers that have career experiences dealing with the newer lubricants and performances compared with what grand-pa used in his early '60s Olds and CorVet engines saw something was happening. Blends and better rated was great w/new engines. Their jury came in and suggested to stay with the engine oils with what the engine was using when it went over the 100+K mark. The discovery was; the new, thinner, cooler running lubs were washing out old crud places that up till recently could hold-back the internal crank air pressures the engine produced on normal, no-hard driving, blowing by old seals, gaskets, etc. Do not be all that surprised if the engine begins knocking some cool blue morning. I would (suggest) fall back to the orig weight or five above, like 5 to 10, 10 to 15 (15w30). Good luck.
Trending Topics
Continue to my last post here; I forgot to mention, with most cases as this, at this point as you've described, it will be difficult to turn it back to old normal, places (passages) have open and it may require much more than dumping sealer in and going back to the old usual crankcase brand oil.
