Transmission oil cooler Line Replacement.
Old Feb 3, 2019 | 06:43 PM
2002RAM2002's Avatar
2002RAM2002
Default Transmission oil cooler Line Replacement.
Hey Guys,
I contacted you guys several weeks ago concerning the "Transmission oil cooler line" identification. You guys were very helpful and I was able to obtain the lines, both upper and lower.....Thanks so much...
The reason for this thread concerns the lines, and the install of them.
Has anyone done this before? I mean, trying to get the new ones on without breaking them because of all the bends they have is a real pain. Is it any easier on a lift?
Any and all feedback is truly appreciated.
Old Feb 3, 2019 | 06:52 PM
When they install them at the factory, they have a bare frame they set the engine/trans/etc onto. You don't have that luxury. Basically, you have to snake them around the various things in the way, to get them in. Being on a lift will give you MUCH more wiggle room under the truck....
Old Feb 3, 2019 | 08:16 PM
2002RAM2002
Wow, I didn't know that....I thought they did this stuff after the fact. No wonder I'm having so many issues....
I tried snaking it around, but I am still encountering issues.....and unfortunately I don't have a lift to use, so I am on the ground......
I wished they make a more flexible line.
Old Feb 4, 2019 | 01:48 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Technically you can make them more flexible but you probably don't have the tools to do it.
Old Feb 4, 2019 | 10:30 AM
2002RAM2002
How so? Like bending?
Old Feb 4, 2019 | 11:30 AM
MoparFanatic21
You could crimp on robber hose to it but you need a special crimper
Old Feb 4, 2019 | 04:33 PM
2002RAM2002
ok. thanks
Old Feb 4, 2019 | 09:28 PM
MoparFanatic21
ok. thanks
Best bet it try and snake it around things. You can bend them slightly!
Old Feb 5, 2019 | 02:52 PM
2002RAM2002
cool thanks.
