Need help finding a part
Old Feb 4, 2019 | 06:24 PM
rob0225's Avatar
rob0225
Default Need help finding a part
I'm trying to locate two parts, I've searched the internet as best I can and have come up empty. The first is the connector for a heated seat switch, I'm told this is off of a 2005 Dodge Ram. The second is the rubber insert for the cubby. I've posted pictures below to show the type of switch and the cubby. Also, would I be able to use these switches to turn after market heaters on and off? Thanks!
Rear connector for heated seat switch
Heated seat switch and cubby hole.
Old Feb 4, 2019 | 06:55 PM
Have you checked ebay or a junk yard?
Old Feb 4, 2019 | 08:00 PM
rob0225's Avatar
rob0225
Yes I have
Old Feb 4, 2019 | 09:31 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You can use them to turn on aftermarket heated seats, if you know what the wires do for the factory switch. Let me see if I can help you find the connectors but the rubber mat is a no go i can tell you they much unless you find it out of another truck
Old Feb 4, 2019 | 09:38 PM
rob0225's Avatar
rob0225
Thanks, I appreciate it.
Old Feb 5, 2019 | 11:31 AM
rob0225's Avatar
rob0225
I found the connectors. These are actually momentary switches. My current after market switches are toggle switches with LOW-OFF-HIGH is there a way to convert these to toggle versus momentary? Thanks.
Old Feb 5, 2019 | 11:41 AM
Replace them.
Old Feb 5, 2019 | 11:56 AM
rob0225's Avatar
rob0225
Replace them.
I don't understand the answer? I want to try and use the stock switches but need to convert from momentary to toggle type switch. Is this possible?
Old Feb 5, 2019 | 12:36 PM
MoparFanatic21
They aren't momentary they are toggle switches.
Old Feb 5, 2019 | 02:23 PM
You can't convert switches from momentary to toggle. it's *possible*, but, only if you have the manufacturing facilities...... you aren't going to do it at home.
