AC problems
Old Apr 28, 2019 | 08:39 PM
Henry Hoffmann's Avatar
Henry Hoffmann
Default AC problems
I have an '07 Dodge Ram. My AC is not cooling as it should. It gets cool but not cold. I noticed the high pressure line is icing up from the firewall to about half way to the core support. I have pressure readings of 70-75 on the low side and 80 -95 on the high side at 80 degree outside temperature. What might my problem be?
Old Apr 28, 2019 | 09:04 PM
Is that with the compressor running?????
Old Apr 28, 2019 | 09:07 PM
Henry Hoffmann
Default AC problem
That is with the compressor running, clutch engaged after running for about 5 minutes with everything on high.
Old Apr 28, 2019 | 09:10 PM
Then something really isn't right there. Your high side pressure should be north of 200..... and its not..... So, either the compressor is failing, or perhaps the orifice tube has blown out.
Old Apr 28, 2019 | 09:13 PM
Henry Hoffmann
Default AC problem
I was leaning towards the Orifice tube being the problem but I don't know much about AC work. I watch a bunch of videos to determine that.
Old Apr 28, 2019 | 09:15 PM
Yeah, I am not even sure it's replaceable by itself..... may have to replace the entire line.
Old Apr 28, 2019 | 09:17 PM
Henry Hoffmann
Default AC problem
Thanks I will look into it after getting more replies. K don't want to just start changing parts.
Old Apr 28, 2019 | 09:18 PM
Yeah, that gets expensive in a hurry.
Old Apr 29, 2019 | 12:07 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Probably the compressor. Orifice tube will spike the pressure, unlike an expansion valve which can spike or equalize it.
Old Jun 9, 2019 | 11:16 PM
Tyler Willis's Avatar
Tyler Willis
Orifice could be plugged half way or dirty.
