headlight switch with fog lamp feature
Old May 3, 2019 | 08:46 PM
fj5gtx's Avatar
fj5gtx
Default headlight switch with fog lamp feature
This 04 2500 truck didn't come with fogs, but I bought a set of jyard foglights with harness since the truck did ship with the harness to the bumper. I also bought a replacement headlight switch + fog lamp from AMParts, only $28. Assembled and wwitched it on and both fogs lit up. yay!
But there is no backlit indicator on the switch when I pull the **** out. Isn't it supposed to light up in the lower left corner? Been a while since my 04 1500, can't remember those details.
Thanks!
Old May 4, 2019 | 07:28 PM
fj5gtx's Avatar
fj5gtx
Grabbed a used one today, no illumination - so I'm assuming they don't light up when you turn on the fogs... 2nd gen does. Weird.
Old May 5, 2019 | 01:04 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Supposed to, but it may be because yours was not a factory install
Old May 5, 2019 | 05:51 PM
fj5gtx's Avatar
fj5gtx
Could be, but they do function like you'd expect - although no feedback illumination in the switch.
Old May 6, 2019 | 08:31 PM
ol' grouch's Avatar
ol' grouch
My '02 doesn't light up.
Old May 8, 2019 | 12:11 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Just because yours doesn't lol....
Old May 8, 2019 | 07:40 AM
fj5gtx's Avatar
fj5gtx
Seeing is believing Thanks!
So I contacted am-autoparts via their chat yesterday afternoon. I asked if their switch had an ON indicator in the lower left that lights up when you pull on the fog lights. They replied "yes". Then I said I have one of their switches and its not lighting up, is there a way to test the switch. They then replied that their switches don't light up. I didn't bother to highlight the 180 degree turn in answer for him, I just laughed and closed the chat window...
I think I'll have to look at the wiring diagram to figure out how to test the switch and see if its the switch or the truck side of the circuit.
Old May 8, 2019 | 08:22 AM
I wonder if one of the modules needs to be clued in that you now have fogs, so it will turn on that indicator.......
Old May 8, 2019 | 11:44 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
In a CAN bus vehicle it would, in a PCI bus vehicle there has to be a signal wire going somewhere to illuminate it. Without looking at a wiring diagram, if it's anything like a similar year Liberty, adding the factory fog light add on kit routes a wire up to the clockspring, this then sends the signal from the multi-function switch to the BCM to tell it to light up the dash indicator.
Old May 8, 2019 | 10:56 PM
fj5gtx's Avatar
fj5gtx
I doubled checked that the fogs went out when high beams come on, and they do go out.
Looking at the FSM didn't really help me much, I know there are more than a couple pins on the back of that switch...
