Upper hose very hard in high temperature running
Old Jul 2, 2019 | 04:35 AM
BigHorn70's Avatar
BigHorn70
Default Upper hose very hard in high temperature running
Hello from Belgium.
I got a upper hose near the radiator very hard when engine is hot. Is it normal? Is it not a problem of high pressure in cooling system?
Thanks for your help
Old Jul 2, 2019 | 07:33 AM
Yep, normal. Cooling system will build pressure to 16-18 PSI when engine is fully warmed.
Old Jul 2, 2019 | 08:17 AM
BigHorn70's Avatar
BigHorn70
How can i know my pressure ? Is there a sensor or trought OBD?
Old Jul 2, 2019 | 08:20 AM
No sensor. Radiator cap regulates pressure. If it isn't blowing coolant out of the overflow tank, it's all good.
Old Jul 2, 2019 | 08:26 AM
BigHorn70's Avatar
BigHorn70
Does the lowest hose can be very hard also?
i mean its very, very hard on the top
Old Jul 2, 2019 | 02:30 PM
All hoses should be pretty hard once the engine is up to temp, they are all part of the same system.
Old Jul 4, 2019 | 12:10 PM
66three83's Avatar
66three83
You don’t realize how much pressure 17lbs is. If you tried to hold 15lbs in your mouth, you’d rip your cheeks off of your jaw!
Old Jul 4, 2019 | 03:41 PM
Alex Medeiros's Avatar
Alex Medeiros
Yikes that's an image to think about
Old Jul 4, 2019 | 04:20 PM
BigHorn70's Avatar
BigHorn70
Thats a strange comparison. Ok guys thanks for your advises. I guess it means its normal
Old Jul 4, 2019 | 06:16 PM
66three83's Avatar
66three83
HaHa, only analogy I could think of!!!!
