2002 ram 1500 brakes
Old Aug 10, 2019 | 02:02 PM
srmdodge02's Avatar
srmdodge02
Question 2002 ram 1500 brakes
Brake issue-
I have 125k miles on ram 2002 1500 (4wd - 5.9L V8). Installed new front calipers, rotors & pads. bleed the brakes starting from the farthest away from the master cylinder (twice). Brake pedal is soft & goes all the way to the floor. Changed out the master cylinder (with new one) and bleed brakes twice. Pedal still is soft and goes to the floor. Any tips or solutions would be greatly appreciated!
Thanks very much,
srmdodge02
Old Aug 10, 2019 | 03:37 PM
Are you losing any fluid? Pulled the drums, and had a look? My wheel cylinders were leaking pretty bad, but, there was no evidence of it outside the drums....
Old Aug 10, 2019 | 06:35 PM
fj5gtx's Avatar
fj5gtx
This occurs sometimes, people reverse the calipers and the bleed valve is not at the top. That means you don't get all the air out of the system. Check that first.
Old Aug 11, 2019 | 01:26 AM
ol' grouch's Avatar
ol' grouch
Originally Posted by srmdodge02
Brake issue-
Thanks very much,
srmdodge02
Correct caliper on the correct side? I've cleared a lot of problems where the guy working on it removed both calipers at once and swapped them by mistake.The bleeder will be on the top if it's on the right side.
Old Aug 11, 2019 | 07:10 AM
jrsick's Avatar
jrsick
Did you bench bleed the new master cylinder?
Old Aug 11, 2019 | 06:08 PM
72rtchallenger's Avatar
72rtchallenger
This is what it sounds like , because if the bleeder is on the lower side then air gets trapped at the top,,its very easy to not pay attention an get the drivers side swapped with the passenger side and no amount of bleeding will resolve the issue
Old Aug 26, 2019 | 01:48 PM
srmdodge02's Avatar
srmdodge02
Smile Soft brakes
Hi Guys,
Problem fixed, I had the front calipers reversed. Switched them to the correct side & the brakes work great!
thanks for all of the tips!
Scott
Old Aug 27, 2019 | 09:09 AM
ol' grouch's Avatar
ol' grouch
Hi Guys,
Scott
Down the road you'll get a reputation as being really good at mechanics by remembering that. I've seen guys with years of experience do that and it is REALLY easy to do. I'll mark the boxes when I buy them to keep track of which side something like calipers, tie rod ends and so on go onto.
