transfer case
Old Sep 4, 2019 | 09:46 PM
I suspect that when you pull the case apart, to replace the case half, you find out why the gears are eating holes in the case...... which is also going to need to be fixed. See if you can find a used case. Replace the whole thing. Otherwise, you are just going to compound the problem, and your truck will be down even longer.
Old Sep 4, 2019 | 09:51 PM
brownml85's Avatar
brownml85
thanks for the advice. we will see what happens in a week or so when the part comes in...
Old Sep 5, 2019 | 08:57 AM
dodgetruck2's Avatar
dodgetruck2
Yea I definitely would not drive it, ive seen neglected front driveshafts send those buggers swinging and itll rip the floor pan right out of the cab, possibly taking your feet with it, happened to a buddy of mine luckily no cab damaged but it ripped the OD housing out of the trans along with every other hose line wire ect under the truck, 10k+ in damage i think he said, all because people cant afford to replace/maintain that $300ish CV joint....
Old Sep 29, 2019 | 10:54 AM
Aaron H's Avatar
Aaron H
While you’re on the topic and i’ve talked to you before and know you’re extremely knowledgeable- can you recommend me a good rebuild kit for a NP 233D? I’ve already rebuilt my 5.9 and 46re so i might as well do the t case. Thanks
Old Sep 29, 2019 | 11:18 AM
Summit racing has a selection of kits..... I think most of them are Motive Gear..... they have a reasonable reputation at least.
Old Sep 29, 2019 | 02:31 PM
Aaron H's Avatar
Aaron H
Damn unfortunately they don’t have and np233 stuff. Do you know if the Np233 D and Np233 C have the same parts? Bc i only see parts for the GM np233
Old Sep 30, 2019 | 06:04 AM
gcburkett's Avatar
gcburkett
I think you could get a used transfer case for 200-300. That's probably I lot better and cheaper than trying to repair something.
It likely to already have damage on the front wheel drive part that was causing the noise.
Old Sep 30, 2019 | 02:58 PM
Alex Medeiros's Avatar
Alex Medeiros
Just don't forget to go with a low milege transfer case, sometimes the cheapest option isn't always the best option...
