Tow group question
Old Sep 13, 2019 | 11:01 PM
pgottuso's Avatar
pgottuso
Default Tow group question
Does the 2006 Ram TRX crew cab with towing group have an integrated break controler?
Old Sep 13, 2019 | 11:23 PM
primem's Avatar
primem
i haven't seen one on a 3rd gen...4th gen I have seen.
Old Sep 14, 2019 | 10:50 AM
pgottuso's Avatar
pgottuso
Default Thanks
I did a little digging and confirmed it does not.
Old Sep 14, 2019 | 04:05 PM
fj5gtx's Avatar
fj5gtx
There generally is a nice connector under the dash to plug in an aftermarket brake controller, keeps you from having to cut up your factory harness. Most brake controller manufacturers have the harness plug.
https://www.tekonsha.com/products/br...wivxzJho5S5JFc
Old Sep 16, 2019 | 01:18 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
3rd gens NEVER came with factory brake controllers. There is a spot to connect one, but you have to get your own. You need the blue plug to go here:
Old Sep 16, 2019 | 01:45 AM
primem's Avatar
primem
and don't just plug and play...check the outputs. I bought a factory connector and the wires were inserted wrong...if I hadn't checked...I would have destroyed my brake controller.
Old Sep 16, 2019 | 10:05 PM
fj5gtx's Avatar
fj5gtx
[QUOTE=Magnoom;3453336]3rd gens NEVER came with factory brake controllers. There is a spot to connect one, but you have to get your own. You need the blue plug to go here:
[/QUOTE
Not true, the 2004 1500 I bought brand new (with tow package) came with one in the glove box. I still have it; used it on my 2000 RAM 2500. But if you don't have one, they are easy to buy aftermarket.
Old Sep 16, 2019 | 11:56 PM
primem's Avatar
primem
the factory supplied the plug to connect to the controller but not the controller.
Old Sep 17, 2019 | 09:53 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
[QUOTE=fj5gtx;3453422]
[/QUOTE
Willing to bet money it wasn't factory supplied nor listed on a build sheet: https://fcacommunity.force.com/RAM/s/equipment-listing
Sounds dealer supplied...factory supplied would have it installed and fully integrated into the electrical system.
Old Sep 17, 2019 | 10:33 AM
fj5gtx's Avatar
fj5gtx
Yep, I meant the plug that inserts into the harness. I had to buy the controller.
