Valve cover bolts!!!
Old Oct 25, 2019 | 08:40 PM
Distrut's Avatar
Distrut
Default Valve cover bolts!!!
So I have an 04 dodge ram 1500 with a 4.7. I have a lot of bolts that are rusted and stripped out. I had to take the valve covers off to replace both heads. Can anyone tell if I can use just regular bolts instead of buying new valve covers?
Old Oct 28, 2019 | 05:55 PM
72rtchallenger's Avatar
72rtchallenger
As long as you get same thread size an length then you can use a bolt from the hardware store , I would recommend a grade 8 bolt or close to that for replacement
Old Oct 29, 2019 | 06:44 PM
Grade 8 for a valve cover? That seems like overkill to me.....
Old Oct 29, 2019 | 07:51 PM
72rtchallenger
it is but why not put in a strong bolt, of course a 5 will do
Old Oct 29, 2019 | 08:30 PM
3 will do as well. Not like they are torqued really tight. And why spend money where you don't need to? If you want expensive bolts, go for stainless steel.
