Need help wiring remote car starter
Old Dec 16, 2005 | 08:36 PM
romic00's Avatar
romic00
Default Need help wiring remote car starter
Hi i have a question about wiring my remote car starter. When i connent the 4 wires to the ignition harness i am a little confused. On the wiring diagram it says starter wire ignition 1 and ignition2, 12 v constant, and acce4ssory 1 and accessory 2 wires. Now is the strarter wire the wire on the start possition of the ignition key? Is the ignition 1 and 2 on the on possition of the ignition key? Is the 12v constant wire on the on position of the ignition key. and accessory is the acc on the ignition key??
Old Dec 16, 2005 | 09:03 PM
romic00's Avatar
romic00
Default RE: Need help wiring remote car starter
I just installed the wires and when i press the start button all the lighs in the dashboard turn on just like i would put the key in the on position but then it turns off.? could that be becasue i didn't connect the tach wire? or what else could it be.
Old Dec 16, 2005 | 11:23 PM
bcashm's Avatar
bcashm
romic, does the remote start work?
Old Dec 16, 2005 | 11:33 PM
romic00's Avatar
romic00
the remote car starter is new. But i cn't get it to start the truck. it only goes to on position then turns off
Old Dec 16, 2005 | 11:38 PM
bcashm's Avatar
bcashm
The tachwire shouldn't be the problem. Did you connct the Arm and Disarm wires in the drivers kick panel. By the parking brake?
Old Dec 17, 2005 | 12:14 AM
romic00's Avatar
romic00
Do you think thats the problem? cause i didn't connect it. Also what are those wires for? to disarm what? thx
Old Dec 17, 2005 | 12:24 AM
bcashm's Avatar
bcashm
I have no idea what it disarms...lol But what I do know is that it will not work unless those are connected. Mine did the same thing. Glad I could help, Let me know if that fixes it.
Bill
Old Dec 17, 2005 | 12:28 AM
romic00's Avatar
romic00
hey did you have to use any capacitors orresistors for that wire? thx
Old Dec 17, 2005 | 12:36 AM
bcashm's Avatar
bcashm
Not for those wires, but did need 330ohm resistor for the parking lights. To make them flash when you hit the button.
Old Dec 17, 2005 | 12:43 AM
romic00's Avatar
romic00
hey thx for all your help but where did u find those resistors??
