Identifiyng 5.7 hemi engine
Old Dec 1, 2019 | 06:31 PM
raul hernadez's Avatar
raul hernadez
Default Identifiyng 5.7 hemi engine
Hello i needing some help in identifying the year of hemi engine thats been swapped into i truck i bought so i can get the proper pcm for it, as of now it has a pcm for 3.7 v6. My guess is this could be causing a few issues i have like a p0443 code that is there soon as vehicle is started even after resetting it
Numbers on head passenger side
Tag on valve cover on driver side believe it says 553021332ca Not sure what top one is but i think it says tnxe5093310011
Pcm part number comes up for 3.7 dodge
P/n is p56028789ae
Sorry for poor pic and angles
Old Dec 3, 2019 | 10:54 PM
fj5gtx's Avatar
fj5gtx
You may need to ask your local dodge service dept for that answer.
Old Dec 5, 2019 | 11:02 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
How are you running a hemi on a V6 PCM?
Old Dec 5, 2019 | 10:55 PM
Alex Medeiros's Avatar
Alex Medeiros
I wonder how it's even possible... I would think it would be messy to say the least.
Old Dec 8, 2019 | 01:57 PM
raul hernadez
Dodge dealer here isnt much help.
runs pretty good asides that i cant get it to pass smog due to a p0443 code which comes on soon as you start the engine.
Old Dec 11, 2019 | 11:56 PM
lxman1's Avatar
lxman1
Site Moderator
Looks like an 03 due to the aluminum valve cover and the 2003 date stamp on the plug wire.
Old Dec 12, 2019 | 06:44 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Part number on the valve cover (if original to the engine) comes back as 03-04. Look on the passenger side cylinder head, if it has EGR it's an 04 1500, if it doesn't it's an 03 or 04 1500/2500/3500.
