5.7 hemi
5.7 hemi
I have a 2004 ram 1500 5.7 hemi the engine died as if someone switched the key off. 02 sensors are good as well as fuel pressure. One cat bad I replaced both, the only way it will run is the throttle half way to the floor and even then the engine runs rough and won't idle. Truck has 196K on it. There are no P codes set, stumped. Paul
Map sensor checks out and also has new plugs.
Cam sensors are in sync. as well as timing.
