Replaced rear axel 2003 ram 1500
Old 03-25-2020, 01:05 PM
gregraschkejr's Avatar
gregraschkejr
gregraschkejr is offline
Originally Posted by TrueDogman
Just ensuring...you have driven the truck since doing the axle replacement?
yup for two days
Old 03-25-2020, 06:02 PM
TrueDogman's Avatar
TrueDogman
TrueDogman is offline
Ok. I know sometimes when sensors are disconnected the vehicle needs to be driven a short distance to turn the light back off. But you have that covered. Back ti checking your wiring again I guess.
Old 03-25-2020, 11:41 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Was the carrier replaced in inside the differential or just the axle?
Old 03-28-2020, 03:48 PM
gregraschkejr
It was the whole axel assembly. I found out what was wrong with the sensor the pigtail had a broken wire in side of it anyone know where I can buy a new one that goes to the center of the rear axle all I'm coming up with on line is the wheel sensor pigtails not the same.
Old 03-28-2020, 05:39 PM
TrueDogman's Avatar
TrueDogman
If your very careful.and work like a watch repairman you can take the connectors apart and make a repair to the pin connector. Orherwise junkyard ?
Old 03-28-2020, 05:42 PM
gregraschkejr
I thought about that but it is impossible to do that with that connector
its one solid piece no seam
Old 03-28-2020, 06:50 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,390 Likes on 3,130 Posts
Need the de-pinning tool.
Quick Reply: Replaced rear axel 2003 ram 1500
