Needing help
Old Apr 24, 2020 | 10:16 PM
Thor Chanmplain's Avatar
Thor Chanmplain
Default Help
Old Apr 24, 2020 | 10:47 PM
Alex Medeiros's Avatar
Alex Medeiros
Originally Posted by Thor Chanmplain
Did something get unplugged? I've never seen/heard of this type of this problem before...
Old Apr 25, 2020 | 05:22 AM
Thor Chanmplain
No I came out after work and that's all I get
Old Apr 25, 2020 | 08:11 PM
Thor Chanmplain
Default Any ideas
Thank you guys for the help. I've looked everywhere and even called my local dealer ship. They have never had this problem before either. I have nowhere left to turn.
Old Apr 26, 2020 | 06:51 AM
Dodgevity's Avatar
Dodgevity
Disconnect the battery terminals, short them out, reconnect and try again. Also, is it throwing any codes?
Old Apr 26, 2020 | 08:53 AM
Thor Chanmplain
Default Help
I already disconnected the battery and shorted it out. The only codes I get are for the EVAP. Starter was replaced as well.
Old Apr 26, 2020 | 10:04 AM
Dodgevity's Avatar
Dodgevity
Does it crank if you put it into neutral? What happens if you hook up a battery charger or jump it? State the code number that you're seeing.
Old Apr 26, 2020 | 02:23 PM
TrueDogman's Avatar
TrueDogman
Yes. I agree with above about battery and its condition. Thats the first thing to check.. Start with the basics. Some of what your telling us doesnt make much sense. Leaving the dash board issue out of the equation at the moment, it sounds like you lost main heavy power feed to your starter. OR a ground issue. Check your main wire leading down to the starter, all the way back to where it originates, and the same heavy positive leads which accompany it.
Another simple test would be to run a battery jumper cable from the negative post of the battery to a good ground on the engine, or even better directly to the starter. Another idea may be to remove the starter and perform a bench test. The starter isnt working so work your way backwards thru the wiring.
Your dash cluster issue could very well be a symptom and not the cause.
Old Apr 26, 2020 | 03:35 PM
Thor Chanmplain
Default Help
Well guys I found it. There was an aftermarket alarm system careful placed and installed in the dash board. After I rewired the truck to original alldata specs truck stats and runs fine. Thank you again for everything.
Old Apr 26, 2020 | 04:23 PM
lxman1's Avatar
lxman1
Site Moderator
Thanks for the update.
