4x4 isn’t working
Old Apr 30, 2020 | 01:48 PM
denysb's Avatar
denysb
Default 4x4 isn’t working
I had a mechanic recently diagnose my truck and he said that the ecu couldn’t even read that the truck was 4x4 any suggestions on what to do next? It’s for a 2006 Dodge Ram 1500 with the 4.7 v8 it has an electronic transfer case.
Old Apr 30, 2020 | 02:27 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
I like how you think we know what year, engine, trans type transfer case/shift you have lol
Old Apr 30, 2020 | 02:34 PM
denysb's Avatar
denysb
Sorry about that forgot to include it buts it’s a 2006 Dodge Ram 1500 with the 4.7 v8 and it has a electronic transfer case
it’s an automatic transmission but not too sure which one it has
Old Apr 30, 2020 | 06:56 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
You have the 545RFE. When plugged in, the ECU view should show it, which leads me to believe either a) he doesn't know where to look or b) it has gotten unplugged somehow. Since it's electronic the shift mechanism should be able to be actuated for testing with the proper scan tool.
Old May 1, 2020 | 12:32 PM
denysb's Avatar
denysb
Oh okay. I have tried to see and locate if something is unplugged under the truck but it doesn’t seem as it is. Would you just recommend taking it to another mechanic?
Old May 1, 2020 | 02:21 PM
master tech's Avatar
master tech
Site Moderator & Tech
Does the lights flash on the control **** panel for the 4x4?
Old May 1, 2020 | 02:27 PM
denysb's Avatar
denysb
No lights flash on the control **** or the dash
Old May 1, 2020 | 09:45 PM
master tech
Okay do you switch the 4x4 by moving the **** on the control panel or the shifter coming thru the floor. If its a ****. Check the wires above the brake brake ratchet. Sometime the wires rub on the ratchet and short out.
Old May 1, 2020 | 10:59 PM
denysb's Avatar
denysb
I switch the 4x4 with the **** on the control panel and I’ll definitely check that out any other things I should look out for?
Old May 2, 2020 | 05:36 AM
95RAM360's Avatar
95RAM360
I’ve seen some actuator housings on both axle and transfer case crack in plastic areas allowing water and grit to enter end shorting them out
