2004 Dodge Ram 1500 OVERHEATING!!!
No we haven't tried that yet.
Give it a shot, and see if it agrees with the gauge. (it should, I think the computer uses the sensor to tell the gauge what to display.....)
Beginning to sound like a blown head gasket though.
Ok. I think my next step would be to check for combustion gases in the antifreeze......which would indicate a head gasket failure or cracked cylinder head. Not sure if there are test kits you can buy in your area or you may have to visit a rad shop. When cold you could try removing gas cap with engine running check for unnecessary bubbles. This isn't always a good trustworthy test tho.
You can also check for head gasket failure by running the engine with the radiator cap off. If the coolant is bubbling at the cap then you have a head/head gasket problem.
Pull some plugs and see if you can isolate location.
I think you know that you shouldn't drive the truck if there is gas in the oil. The oil is no longer a lubricant.
