Would anyone want a free set of ARH long tube headers?
#21
I think factory cats are 400 cell, maybe more and the one on system is now 200 cell (very high flowing cats) so there are emission increased.
Yes, I am rocking stock exhaust. When you get on it, then you can hear more volume from engine. I might put in an high performance muffler (no drone but louder) to utilize the sounds better.
I had 150 a miles drive home. I will reset the PCM an see what happens. The check engine light actually came on while I was heading home.
Is there enough room under there to fit cats that aren't part of the ARH Y pipe right at the collector? I don't really like the placement of the stock cats on the 2500..... they're in such a weird place.
#22
It was for both bank catalyst efficiency. I reset the PCM like an hour ago (adaptions) and will see if check engine light will come back on.
#23
That's what I'm getting currently.... I have exhaust leaks though, which is why I suspect that's happening..
little concerned about getting headers now though....
#24
I wouldn't. If you have a tuner on your truck then you should able to trick PCM that theres cats in the system. I can always put o2 spacers on it to turn off the check engine light. By the way, the check engine light came back on today, probably for cat converters.
#25
I'll figure something out though, as I said before I probably won't be able to get the exhaust system done until September unfortunately, and it's only unfortunate because I'm getting like 9mpg right now with the exhaust leaks I have.
do you think there's room to fit 2.5" cats right off the collectors? I'm waiting on the PaceSetter 80-0016 converters, which won't be here until roughly the end of august, so I hope I don't have to return them, because I'm buying the ARH set without cats......or maybe I should just get the catted set and figure out how to go dual from there??
I really don't know which direction I want to go. We don't do e-testing here any more, but I don't want to go catless in case it ever becomes an issue somewhere.
#26
Seems like a waste of $ to buy their y pipe if you don't intend to use it. In general $1900 is seems like alot to spend on headers. They are stainless, so they won't rust - but they may crack over time. I'd be tempted to get some repro exhaust manifolds and spend the rest elsewhere.... Its a 3/4 ton truck, and the as 04HEMI04 says, it is noticeable in the higher rpm range. How often you racing this 3/4 ton 4x4?
#27
#28
#29
The following users liked this post:
Alex Medeiros (07-25-2020)
#30
Did you get a tune on your truck yet? If not how's it been running after the header install? Any better mileage or anything?
