2004 ram 1500 4wd front end thumping
Old Jul 10, 2020 | 09:39 PM
deuce12vo's Avatar
deuce12vo
Default 2004 ram 1500 4wd front end thumping
so last year my sister was driving my truck and decided to swerve from a deer and hit a guard rail. at the time i had a set of 2013 dodge 1500 20in rims on it. and a few months ago i did a front wheel bearing thinking that was the issue and it’s still there. could it be a front cv axle? or anything else. thank you.
Old Jul 11, 2020 | 07:28 AM
When do you hear it? Does the sound change with vehicle speed? Feel anything thru the steering wheel, or the floor? Worse when cornering?
Old Jul 11, 2020 | 02:49 PM
deuce12vo's Avatar
deuce12vo
i feel it in the floor. it doesn’t happen until i go over 25mph. and i hear it loud when i turn right not as bad when i turn left
Old Jul 11, 2020 | 04:38 PM
Which front wheel bearing was replaced?
It sure sounds like a bearing though..... but, I would expect you would feel some of it in the steering as well. How are the u-joints in your front driveshaft?
Old Jul 23, 2020 | 10:11 PM
deuce12vo's Avatar
deuce12vo
Default passenger side
passenger side
Old Jul 24, 2020 | 08:40 AM
That indicates the drivers side bearing is also having issues.
