Water
Old Jul 21, 2020 | 10:26 PM
Dodgedad02's Avatar
Dodgedad02
Default Water
So I have the r.7 2002 ram q500... Just replaced the timing chain cover, water pump, a lot of sensors, plugs, coils, and finally changed fuel pump and truck ran great... I noticed it didn't have any water in the reservoir started filling it up and it was just gone... Checked everything and found oil in my intake and my oil is like my coffee... Damn near white... I need to know if the gasket for the timing chain could be a reason for the water in my oil... Or do I need to break down and rebuild the whole thing from the head??? And how hard is it to get it unhyperlocked????
Old Jul 21, 2020 | 11:31 PM
Alex Medeiros's Avatar
Alex Medeiros
Sounds like the symptoms of a blown headgasket or something. Clearly water is getting into the oil.
Old Jul 22, 2020 | 08:33 AM
What engine is in it?
Old Jul 22, 2020 | 08:57 AM
jrsick's Avatar
jrsick
The timing chain would not be a cause of coolant in engine oil.
You ask about "unhyperlocked", do you mean hydrolock? What symptoms are you getting that lead you to hydrolock? To answer your question though, you should disconnect your plug wires from the plugs, and remove one plug from each cylinder. Then cycle the starter and see if water comes out of plug holes.
If your engine is running, I'd recommend putting in fresh oil, removing your radiator cap, then starting your engine. If you see bubbles in coolant at radiator cap then head gasket is bad. Make sure the coolant level is topped off in the radiator for this test.
There's other checks and possibilities, start with this and we'll go from there.
Old Jul 22, 2020 | 06:22 PM
Dodgevity's Avatar
Dodgevity
Blown head gasket is the only way I can think of coolant mixing with oil? How long has it been since you did all that work? Did you burp the cooling system when you filled it up? If not, air pockets can form and cause severe overheats. I'm not familiar with your engine, but when you checked the overflow, did you check the radiator too?
Depending on how long you've been running with the oil contaminated, your main bearings might be screwed and it might be better to get another engine. Check your oil pan for metal. That mixture doesn't lube well.
Old Jul 24, 2020 | 03:55 AM
Dodgedad02's Avatar
Dodgedad02
It's a 4.7 magnum...
