2-Piece Rear Brake backing plate?
Old Nov 9, 2020 | 07:42 PM
Jack Steele's Avatar
Jack Steele
Default 2-Piece Rear Brake backing plate?
Hi All,
I have a 2006 Dodge ram 4WD 5.7L vehicle and I'm looking for a 2 piece rear brake backing plate. I do not want to have to remove the axle. Thanks in advance for any help you can provide.
Old Nov 9, 2020 | 09:21 PM
Originally Posted by Jack Steele
Hi All,
Don't think you are gonna find one..... Bite the bullet, pull the axle, and change the fluid while you are in there.
Old Nov 10, 2020 | 12:08 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Then you are **** out of luck lol.....why would you think that such a thing a exists for a mass produced vehicle? Anyway it's not hard to pull an axle out of one side. Did yours get damaged or did it rust out?
Old Nov 10, 2020 | 12:39 PM
TrueDogman's Avatar
TrueDogman
I have seen 2 piece backing plates for different makes models over the years. Haven't seen any for Dodge rears tho
Old Nov 10, 2020 | 06:16 PM
Dodgevity's Avatar
Dodgevity
They exist... but not for Dodge. https://www.1aauto.com/chevrolet-gmc...6/i/1abmk00056
Old Nov 10, 2020 | 07:10 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
That's nice....does a fat lot of good for the OP, doesn't it lol?
Old Nov 10, 2020 | 08:34 PM
Dodgevity's Avatar
Dodgevity
No, that was all for you.
Old Nov 10, 2020 | 08:52 PM
TrueDogman's Avatar
TrueDogman
Good job.
Old Nov 11, 2020 | 12:06 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
No, that was all for ****.
Fixed it for you
Old Nov 11, 2020 | 08:14 PM
fj5gtx's Avatar
fj5gtx
I didn't want to do it either on my 1500 when I had to work on the parking brake actuators... but it wasn't that big of deal to pull the axle. And with those 1/2 ton rears, you gotta keep an eyeball on those lsd shims that crack apart and grind the hell out of your housing. After owning that 1500 for 11 years, I decided I really should just concentrate on 3/4 tons. 1/2 tons aren't really durable enough for my use, and I typically want to load it heavy anyway... 3/4 tons are the way to go for me.
