Squealing Noise At Idle - Please Help
Old Dec 12, 2020 | 02:57 PM
BigCountry55's Avatar
BigCountry55
Default Squealing Noise At Idle - Please Help
2006 1500 4.7 6-speed 4X4
My wife and I were sitting in the drive thru and out of no where, a high pitched squeal started when she started the truck back up to move forward. I immediately thought it was either a belt or pulley of some sort on the engine.
When got back home, we parked and shut it off, I started investigating. Belts are tight, no slop or visible wear to speak of. Pulling all seem good. So I start it back up to listen. In neutral and at an idle, the noise is constant. But to my surprise, the noise isn't coming from the front of the engine. Rather its coming from the back. I crawl under the truck and its coming from the area where the tranny mounts to the motor. So I press the clutch, the noise does change a little in tone, but still a constant squeal. I back up about 50 feet, then drive forward. I try this a handful of times, the noise doesn't go away. I shift into each gear, everything seems to shift just fine.
I'm at a loss because I'm not too familiar with clutches or manul transmissions. I'm guessing maybe the throwout bearing??? Or is there something more to it?
Please help, thank you in advance.
Old Dec 12, 2020 | 06:19 PM
Probably throwout bearing, or the starter is staying engaged.
