INSTRUMENT CLUSTER SWAP, KPH too MPH ?
Old Dec 13, 2020 | 06:57 AM
Bigmincey's Avatar
Bigmincey
Default INSTRUMENT CLUSTER SWAP, KPH too MPH ?
Hoping all you knowledgable folks out there can help me here. Just purchased a 2004 Dodge Ram, 5.7 hemi, 4x4 Laramie. It was a Canadian truck originally, but has spent the last ten years in Japan. Its now a keeper, over here in Scotland, UK. Instrument Cluster is in KPH. I have the chance of a replacement cluster from a 2005 hemi, which is in MPH which is more suited over here.
Question is; Is it a simple swap, plug and play ? Or does it require any re-programming or a re-flash ? Mileage change isn`t a problem as i can get that digitally reset. Just need to know if its a simple swap over ? Image of my dash for reference.
Many thanks, Alan..
Old Dec 13, 2020 | 10:28 AM
Wow. That is one well-traveled truck.
As part of the UK, aren't you folks using KPH there as well?????
Old Dec 13, 2020 | 11:04 AM
Bigmincey's Avatar
Bigmincey
No mate, the UK is MPH, same as you guys. Europe is KPH. We still do MPG ETC OVER HERE.
Alan.
Old Dec 13, 2020 | 11:06 AM
Alan.
Learn somethin' new every day......
I *think* the speedometers scale the same way, regardless of what the local measurement units are. So, theoretically, it should be a direct swap. Don't know if it has to be programmed for the VIN, or anything along those lines.
Old Dec 13, 2020 | 02:19 PM
Alex Medeiros's Avatar
Alex Medeiros
I think that it does need to be reprogrammed.
Old Dec 13, 2020 | 02:49 PM
Bigmincey's Avatar
Bigmincey
Re-programmed to actually work, or just for the mileage ?
Alan.............
Old Dec 13, 2020 | 03:17 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
As long as it's from a gas engine and same bus family (in this case, 2002-2005) yes, but there may be a few electronic hiccups depending on option/build differences between your truck and the donor. The biggest hurdle is usually the mileage and if you have that covered you should be good.
Old Dec 14, 2020 | 12:16 AM
Bigmincey's Avatar
Bigmincey
Cheers Magnoom. I will give it a go, and post back up with the results either way. Cheers dude, Alan........
Old Dec 14, 2020 | 03:37 AM
Alex Medeiros
Alan.............
Mainly for the mileage. Sometimes people run into electrical gremlins when replacing them, but it's not all that common.
