Gauges/wipers not working after I stalling pioneer cd player
I installed a pioneer cd player in my 03 dodge ram 1500 and now my gauges and wipers don't work most of the time. Every once in a while the needles will move but I'm driving blind for the most past. My wipers won't work until the gauges do and then they won't turn off until the gauges work again. Can somebody help?
A guess: you shorted the circuitry in your PDC when you were installing the radio.
You can also check the fuses to make sure they are all good. I prefer to check the backs of the fuses with a multimeter while they are in place, vice pulling them.
A faulty ignition switch could give you similar symptoms. Does the door chime when the door is open and key is in the ignition, in Off position? If so, does the chime stop if you turn key to On?
When you installed the stereo, what did you remove and disconnect? I assume the center bezel and all of the plugs, anything else? Did you disconnect the battery before handling the plugs?
What install kit, if any, did you use? i.e. Metra with steering wheel control dongle.
Trending Topics
