Leaf Spring Mounting Conerns ....
Old Mar 24, 2021 | 07:15 PM
Pelicansplash's Avatar
Pelicansplash
HeyYou does the bushings look good enough too keep using?
in the picture above ?
Old Mar 24, 2021 | 09:11 PM
Not in the best shape, but, *probably* OK. You can burn the old ones out, but, it smells REALLY bad.
Old Mar 25, 2021 | 12:43 AM
Pelicansplash
I have a respirator. I'll ta,e the shackle into a few suspension shops and see if they can locate the proper bushings for me.
I found a guy on YouTube pressing just the shackles specifically.
I wanna do it too 😪
YES MAKE FIRE, MELT STINKY STUFF, MAKE HOLE, PUT STUFF IN HOLE., BEAT CHEST, GRUNT OOGA BOOGA..
Old Mar 25, 2021 | 08:24 AM
jrsick's Avatar
jrsick
You can order the bushings separately. You can get the standard rubber, or go with polyurethane.
Lower stress option is to order shackles with the bushings mounted.
Old Mar 25, 2021 | 02:02 PM
Pelicansplash
Tnankyou fellas . m going too roll with the advice and just count my losses with mismatched parts I recieved .
I have some concerncoabout the business I ordered from. But this isn't the place too vent what I went through.
Trying too get my problem fixed.
Old Mar 26, 2021 | 01:27 AM
Pelicansplash
Do you think that you could shoot me a link for some rubber ones.
I have some new replacement shackles coming hopefully they'll be correct.
but I've like too rebuild my old stock shackles with new bushings.
Thanks man
Old Mar 26, 2021 | 06:09 AM
jrsick's Avatar
jrsick
I always use rock auto first. Summit has good supply of performance parts if you want poly bushings.
I wasn't sure of your truck year or engine, so used 2005 Hemi for this search:
https://www.rockauto.com/en/catalog/...g+bushing,7488
