Leaf spring eye bolts eye bolts stripped.
Old Apr 11, 2021 | 09:41 PM
Pelicansplash's Avatar
Pelicansplash
Default Leaf spring eye bolts eye bolts stripped.
2005 ram 1500 4x4 slt 5.7 hemi. 89k miles.
Forward and rear lower eye bolts and nuts stripped but accessible and removable.
Is there a trick too replacing both eye bolts and nuts without
lifting and suspending/sagging rear axle and diff. Or loosening the torqued U-Bolts
that have less than 30 miles .
The expert technical advisor sent me the wrong shackles..
finally recieved right Eqip. But no replacent eyebolts and nuts
and it wasn't even a suggestion from the expert advisor.
Let's just say after his statement "I'm not trying too insult your intelegence",
Looking up my VIN. " Go take more pics for me. " measure width of bushing
getting loud at me because i gave the wrong measure.
I felt belittled, humiliated, condecended , and i just gave that guy 700 bux.
He didn't want too eat the cost of correct parts and shipping. Admit to
the mistake too his boss. This is why I'm having too replace my
hardware. ITS JUST EDUCATION .
ONWARDS...
So after doing both sides of leafsprings twice
Eyebolts and steele lock nut need too be replaced
again.
2nd Q?
Whats the goto supermarket of nuts bolts, eye bolts, fasteners, and such ?
For hard too find bolts?
Mv invoice says the bolts are 9/16 4.5 ". Invoice says nothing about the
Thread Count/ Pitch/ Fine/ Course on these bolts
The steele locking nut is a 9/16 Inch 12 .
On inovice.
What kind of hardware/ nut bolt washer stack should I use
too eliminate the steele lock nuts.
with fresh 9/16 4.5 inch bolts
Should I use course 12 TPI . 18 TPI fine ?
Nuts and Bolts
What does the 12 pertain too I'm assumeing its thread's per inch? TPI
Thanks fellas...
Last edited by Pelicansplash; Apr 12, 2021 at 02:25 AM. Reason: Additional info added.
Old Apr 12, 2021 | 07:47 PM
jrsick's Avatar
jrsick
You should get a grade 8 bolt with a locking nut.
Companies that manufacture leaf springs will also sell the bolts. Take a look at Husky Spring part number SHB91645. The torque setting on these is not high, I think 40 ftlbs or so.
Old Apr 12, 2021 | 10:41 PM
Pelicansplash
Thankyou .
Am I going too have too lift rear and suspend axle pull the u bolts to get the load off Leaf spring eyes to replace the eye bolts ? Or is there a trick?
And should I get new u bolts as well at this point. 40 miles on them but been torqued .
Old Apr 13, 2021 | 10:55 AM
If you suspend the axle, then all the weight will be hanging on those bolts..... Finding the 'happy spot' where there isn't any tension on the bolts is fun, but doable.
Old Apr 13, 2021 | 03:18 PM
Pelicansplash
So maybe a bit of upward pressure on either side of the axle ?
What about the u bolts they been in and out a few times now? Should I get new ones now ?
Or are they good to go still ? I just bought them ?
Old Apr 13, 2021 | 03:32 PM
I would jack the truck up by the frame, get the axle almost off the ground. Put a jack under the pig, and once you have the bolts loose, experiment with lifting/lowering the axle to get the bolts out.
I think a lotta folks recommend replacing u-bolts if you take them off..... Not sure if that still applies to new ones though..... I have re-used them in the past, with no ill effect.
Old Apr 13, 2021 | 03:42 PM
Pelicansplash
10-4 Under stood..
Thankyou for reading and answering all my crazy long questions..
I do it too make answering a bit easier remove the guess work
as best I can.
Old Apr 13, 2021 | 04:22 PM
That's what we are here for.
It's a fun job...... easier if you have someone to help, even if it's just a tool monkey. (that's what kids/grandkids are for. )
