2004 Ram 1500 5.7 idle issue
Old May 7, 2021 | 07:12 PM
Matt Chursinoff's Avatar
Matt Chursinoff
Default 2004 Ram 1500 5.7 idle issue
Just got the truck running it has a new PCM also program the ETC throttle and clean the MAF sensor. But the truck is surging at idle and will stall any ideas not throwing any codes except that it only has 2 o2 sensors and was running fine with them.
Old May 7, 2021 | 07:59 PM
Vacuum leak?
Old May 8, 2021 | 08:10 AM
jrsick's Avatar
jrsick
take a look at the plugs, they will give you a lot of info.
If you diagnose a lean condition, I would not drive the truck again until that is addressed.
I agree with heyyou that you could have a vacuum leak, many times this will result in lean burn.
You could also have a lean or rich condition caused by modifying your O2 sensors.
What's your gas mileage been?
Old May 9, 2021 | 05:06 AM
Matt Chursinoff
Here is a video
Old May 9, 2021 | 09:56 AM
Video not showing.
Old May 13, 2021 | 11:13 PM
Moparguyram's Avatar
Moparguyram
Could be something as simple as the crank sensor. On an '04 Hemi, it's on the right side of block, 1 bolt & a wiring connector and under $30 for the part.
