04 Ram 1500 5.7 hemi 4x4
So my throttle is acting weird drive it normally it’s fine you floor it and it dies out until you let off and get back in it. Three codes for MAP, IAT, and Coolant Temp Sensor. So far I’ve replaced all three sensors and put a throttle body off a running and driving 5.7 and it’s still acting up. Tried to erase codes and as soon as I do they come back. Any help? Anyone dealt with this? I’ve also swapped computers to see if that would help and it didn’t. Help would be appreciated!
The following users liked this post:
BrysonElliott15 (07-05-2021)
Volt meter.
Most sensors get a 5 volt reference signal from the PCM, modify the signal, (change the voltage) and send it back. If the reference signal isn't correct, then nothing else will be either. Since you are getting codes for multiple sensors, so far as I know, the only thing they have in common is the wiring that gives them their reference signal.
![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
Volt meter.
ok and if it’s off how do you go about correcting that? All the sensors are new.?
