Do I have 2 wheel or 4 wheel ABS?
Old Aug 16, 2021 | 09:17 PM
SnowBeast428's Avatar
SnowBeast428
Default Do I have 2 wheel or 4 wheel ABS?
So i have a 2007 Ram 1500 SLT 4x4 Vin: 1D7HU18247S229627 and I can't tell if I have 4 wheel ABS or not. I only see 2 hard-lines going from the master cylinder to the ABS module and weirdly enough there's only 1 tire in the front (drivers side) that has what looks like a single electrical wire going to it. The passenger tire from what I can tell has no wire going to it at all. I have what looks like rear discs as well.
Old Aug 16, 2021 | 10:58 PM
Alex Medeiros's Avatar
Alex Medeiros
I would think that 2WD would only get 2 wheel ABS, while 4WD would get 4 wheel ABS...
Old Aug 16, 2021 | 11:43 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Nah....I have a 2wd with 4 wheel ABS lol. Go here and enter your VIN: Equipment Listing
Old Aug 16, 2021 | 11:51 PM
master tech's Avatar
master tech
Site Moderator & Tech
So I looked up your brakes by the Vin, you have 4 wheel ABS.
Old Aug 17, 2021 | 12:10 AM
SnowBeast428
Mine looks different than the previous guy, it says "4 Wheel Disc Rr Anti-Lock Brakes" and his says "Anti Lock 4 wheel disc". Theres also the issue iof no wire on the passenger side brake caliper.
Old Aug 17, 2021 | 12:40 AM
master tech
Can you post a picture of the ABS module under the hood. I can tell you if you have RWAL or 4 wheel ABS.
Old Aug 17, 2021 | 01:22 AM
SnowBeast428
I'll have to do that tommorow. All I know is that there is two hard-lines from the master cylinder going to it and to the far right of the module there's something that looks like a rubber button on the top.
Old Aug 17, 2021 | 12:51 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Mine is a 2003, you have a 2007. Verbiage changes over the years; it's the same thing.
Old Aug 17, 2021 | 05:26 PM
jrsick's Avatar
jrsick
You could have front ABS but previous owner removed the wire on the passenger side.
Old Aug 20, 2021 | 03:22 PM
TOTALCHAOS69's Avatar
TOTALCHAOS69
There’s no wheel sensor on the right front. It’s in the left hub assembly only.
