Siphon gas
Old Aug 19, 2021 | 01:21 PM
Grayslope1912's Avatar
Grayslope1912
Default Siphon gas
does anyone know an easy way to siphon gas from gas tank - truck is a 2005 dodge ram 1500
Old Aug 19, 2021 | 01:53 PM
ol' grouch's Avatar
ol' grouch
Do you have an air compressor? Get 7 or 8 feet of fuel line hose and feed it into the gas filler neck. You'll have to wiggle it to get around the bends. When it bottoms out, wrap paper towels around the hose. Stick an air gun into the tank past the towels and use it to pressurize the tank. Have several fuel cans ready because once it starts siphoning, you just leave it running. It's pretty obvious what you're doing so you do it in daylight.
If you're trying to steal gas, suck on the hose until you get a mouth full of gas.
Old Aug 19, 2021 | 02:44 PM
If you slice the end of the hose at a bit of an angle, you can just blow air (from your compressor....) past the end of the hose, and it will start a siphon. Getting the hose into the tank is the fun part. Newer gas tanks have a ball valve in the filler neck, that closes it off in the event of a rollover. Makes it impossible to get the hose past it.
Old Aug 19, 2021 | 03:44 PM
Grayslope1912
My days of stealing gas are long gone -just to darm old to mess with stuff like that. However yes I do have an air compressor and thanks for the info. But a question - the truck is an 2005 and I'm sure it has a valve that closes in the event of a roll over. Would this prevent me from siphoning the gas? (the reason I need to get the gas out of the tank is that the gas is over a year old)
Old Aug 20, 2021 | 07:21 AM
How much is in there? If less than half a tank, just refill with 89 or 91 octane, call it a day. Another option would be to pull the fuel line at the engine, route it into a container large enough, and jump the fuel pump relay.
Old Aug 20, 2021 | 10:26 AM
ol' grouch's Avatar
ol' grouch
The siphoning comment was for others who read the messages and are less principled. As for old fuel, like HeyYou said, if the level is low, fill it with fresh. I prefer to go with straight gasoline (E0) and just run it out. We have a few ethanol free pumps around here, but it IS a bit pricey.
Old Aug 20, 2021 | 12:41 PM
Grayslope1912
unfortunately its a full tank. I think the best track is to jump the relay as HEYYOU stated and get it down to a half tank & refill with 91 octane.
Thank you all for your thoughts!
