2005 Dodge Ram frame repair
Old Aug 21, 2021 | 08:31 PM
fosterjeff00@yahoo.com's Avatar
Default 2005 Dodge Ram frame repair
Does anybody know if the foam inside a 3500 frame is flammable? or if there is suppose to be foam inside the frame ?
just trying to weld some plates on the outside of the frame until I can get a new frame
Old Aug 21, 2021 | 10:03 PM
I am thinkin' that if you get it hot enough, it'll burn, and likely give off toxic fumes. Welding will certainly get it hot enough......Think I would make an adapter for my garden hose, with a stiff, small diameter pipe, for putting out fires inside frame rails, before getting started.
Old Aug 21, 2021 | 10:07 PM
Default Lol
Lol yeah I know I need to be ready but did these frames come with foam inside them from the factory or did some dumb *** put it in there to sell the truck
Old Aug 21, 2021 | 10:10 PM
No clue on that. It *might* be factory, and was used to dampen vibrations/quiet the ride...... The factory doesn't consider rust repair when they are rolling off the floor.
