4x4 question
Old Oct 24, 2021 | 05:05 PM
  #21
You need a real service manual, to see how things are supposed to work.
Old Oct 24, 2021 | 05:17 PM
  #22
Tony Sarmiento's Avatar
Tony Sarmiento
You would think that, but it does not show the same front differential that I have.
Old Oct 24, 2021 | 05:37 PM
  #23
Wow. Now THAT is strange. Does it show the solid axle front end?? Wonder if an 03 would have the right stuff.....
Old Oct 24, 2021 | 06:11 PM
  #24
Tony Sarmiento
Yes solid axel
Old Oct 24, 2021 | 07:13 PM
  #25
Publisher screwed up. The 1500's didn't have the solid axle in 02.
See if you can find something newer, even on PDF, hopefully, it'll have better pics/diagrams.
Old Oct 24, 2021 | 09:13 PM
  #26
Tony Sarmiento
I found a 2003 on ebay, ordered it. 30.00
Old Oct 24, 2021 | 09:27 PM
  #27
00t444e's Avatar
00t444e
You can do that if you take the CVs apart and just run the stubs in the hubs.
Old Oct 24, 2021 | 09:59 PM
  #28
Tony Sarmiento
Thanks ot444e, if I can't fix it I'll do that.
Old Oct 25, 2021 | 12:45 PM
  #29
Tony Sarmiento
Okay since I can't find any diagrams on this. I found a video on the left, drivers side shaft and it shows a bearing on the outside end of the housing. Do you think I should try to install a bearing. I know that there has to be room for the seal to seat.
There was nothing there when i pulled it apart, so I'm just guessing.
Old Oct 25, 2021 | 01:22 PM
  #30
Tony Sarmiento
at 3:19 on this video you can see the seal and bearing. But this is the driver side.
Any thoughts would be welcome.
Thanks,
Tony
