Lamp Out waring light
Old Nov 7, 2021 | 11:50 AM
taordw's Avatar
taordw
Question Lamp Out waring light
2005 2500 Hemi quad 4x4, always getting the lamp out warning. It will go away for a month or 2, then find its way back for a month or 2. Light assembly's new 3 years ago. I do have a plow not sure if it could be the light controller. Drivers side headlight only
Thx
Tim
Old Nov 7, 2021 | 12:18 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
It's the crap rear lamp circuit boards. I finally gave up and found a set of LED housings that I didn't hate.
Old Nov 7, 2021 | 04:40 PM
95RAM360's Avatar
95RAM360
My lamp out did that turns out filament in right front blinker was broke, but enough to keep contact…..I had to trace it down cuz bird hunting on dirt roads, every bump, ding ding ding ding cuz the filiment kept losing and catching contact
Old Nov 7, 2021 | 06:14 PM
It doesn't tell you WHICH lamp is out??
Old Nov 7, 2021 | 07:10 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
If you have the fancier overhead EVIC it does (mine was always the right rear). If you just have the OTIS or nothing then you just get the LAMP OUT in the cluster with the annoying *** constant ding.
Old Nov 10, 2021 | 10:35 AM
taordw's Avatar
taordw
mine is always left head light
Old Nov 10, 2021 | 10:46 PM
95RAM360's Avatar
95RAM360
my left stopped working, and I bridged it to fog lights. Replaced FCM, no change, replaced fuse box, problem solved and no more bridge to fogs
