What is this for
Old Nov 9, 2021 | 02:40 PM
Daniel Reinhart's Avatar
Daniel Reinhart
Default What is this for
I have a Transmission line leaking and went to put a slice in it. And as I was cutting the line broke at this fitting. I have tried to look up what this block is for and can't find anything. I went to see about a hole new line and the way it looks it goes from the cooler to the Transmission and bypass this block.
This is on a 2007 ram 1500 with a 5.7 hemi
Last edited by Daniel Reinhart; Nov 9, 2021 at 02:41 PM. Reason: Adding my truck info
Old Nov 9, 2021 | 06:32 PM
Where do the lines come from/go to? Wonder if that's a thermal bypass....
Old Nov 9, 2021 | 06:34 PM
Daniel Reinhart
These lines are my Transmission Cooling lines.
Old Nov 9, 2021 | 06:38 PM
OK, so, I see (potentially) four lines there, on from the trans to the block, one from the block back to the trans, and I would guess the other two go up to the radiator/aux cooler (if equipped....)?
If that's the case, just take a rough measurement how long the broken line needs to be, go to your local parts store with the dead one in hand, and get one the right length, (or close enough) with the correct fittings on the end. You can hand bend it to fit.
Old Nov 9, 2021 | 06:48 PM
Daniel Reinhart
Is this block something I need. Someone said that it is thermo bypass
Old Nov 9, 2021 | 07:32 PM
It might be, no idea really. Looks like there might be a temp probe in there as well, just broken off. But, why make it more work than it really needs to be? Are all the lines in that bad of shape? If they are, the do what ya gotta do.
