Oil under driver side front axle. What broke and how much is it gonna cost?
Old Feb 19, 2022 | 02:53 PM
scottkeen's Avatar
scottkeen
Default Oil under driver side front axle. What broke and how much is it gonna cost?
Noticed some oil today under the driver side front axle of my 2007.5 Ram 3500 6.7L
The mechanic told me several months ago that one of my shocks was leaking. Most of the oil looks like it's coming from the bottom of the shock where it's bolted. I'm wondering if this is that problem. I hope this is just a leaking shock, or is this is a bigger problem. What do you think?
The top of the engine bay is dry, no oil leaks I see from up there.
EDIT: There was no oil on the front diff cover. It was just shiny, but not oily, it was dry. Most of the oil looks like it's coming from the bottom of the shock.
Here I'm on my back looking up at the shock from under the axle. It's very oily where the shock attaches. (yes, I know it's rusty... east coast snow, ice, salt... it's been sprayed with a rust converter but looks like it needs it again). I think 99% this is the leaking shock that my mechanic said was leaking 4 months ago.
Old Feb 19, 2022 | 03:25 PM
No way to tell without getting under there and identifying exactly where it’s coming from
Old Feb 19, 2022 | 06:13 PM
Dodgevity's Avatar
Dodgevity
Hard to ID exactly when everything is covered. Wash it down with some engine cleaner and you should be able to tell after that.
Old Feb 20, 2022 | 12:37 AM
master tech's Avatar
master tech
Site Moderator & Tech
Did you check the fluid level in the front diff? And it smell like gear oil or power steering. Could also be fluid leaking from the shock.
Old Feb 20, 2022 | 02:30 AM
rtmtrrdr's Avatar
rtmtrrdr
Pull the shock out and you’ll instantly be able to tell where the oil is coming from and if the shock is blown
