Spark Plugs
Old Mar 31, 2022 | 11:43 AM
GRed's Avatar
GRed
Default Spark Plugs
Ok, 08 4.7 I was reading on here bout the plugs these 4.7 uses. copper core vs FR8TE2 OE GENUINE Yttrium Spark Plug ..I did call the dealer and this is how I got to this type of plug they recommended. is what I have in there now and been in their since 69k+ but I'm ready to change them out
Question
what's the difference with the copper core and copper plus ?
I also understand per manual the exhaust changes out every 100K ?
any help would be appreciated
Thx
Old Mar 31, 2022 | 02:18 PM
Copper core, and copper plugs are just two terms for the same thing.
The exhaust changes?? Hhhmmm.... I could see the O2 sensors..... they do have a finite life span. NTK or denso only on the sensors please.
Old Apr 1, 2022 | 08:36 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Exhaust plugs. 08 4.7 uses two different types of plugs because it has 16 of them (dual plugs per cylinder).
Old Apr 1, 2022 | 03:47 PM
GRed's Avatar
GRed
So the exhaust takes a diff plug ? for all the Yttrium that I have in there now I should've used a diff plug for the exhaust?
Old Apr 1, 2022 | 03:50 PM
GRed's Avatar
GRed
What do you think about these type of plugs FR8TE2 OE GENUINE Yttrium Spark Plug vs copper one's
Old Apr 1, 2022 | 09:39 PM
The older trucks have real issues with rare-earth plugs where coppers are recommended. Tends to lead to mystery misfires..... Not everyone experiences that, some have no trouble at all. It's luck of the draw. If they aren't causing any trouble, leave 'em in there.
Old Apr 2, 2022 | 07:49 AM
jrsick's Avatar
jrsick
My understanding is that the exhaust side plugs do not fire on the compression stroke, and are a pain to get to. Dodge recommends iridium for service interval purposes. The plugs you mention will work fine.
Old Apr 2, 2022 | 07:25 PM
GRed's Avatar
GRed
I appreciate it..I went on a 4 hour trip to EL Paso from Albuquerque 275 mi. and the closer I got to EL Paso my mileage went up by the time I got there
it was over 22 miles to the gal. Same coming back and only burned about 3/8 of a tank I have to go again in 3 wks
but I have noticed a ticking sound on start up not the exhaust bolts this goes away after warm up I was thinking putting in some upper lifter Lub before I go
any ideas?? other than this I have had any issues
Old Apr 2, 2022 | 08:37 PM
Dodgevity's Avatar
Dodgevity
The lifters are hydraulic. They tend to lose oil while sitting, so they tick until they prime up with oil again. I replaced all of mine at 313K. Lifter finally locked up and a rocker ejected. Run thin full synthetic oil for quicker flow to upper reaches.
