Floor Jack capacity and Jacking Points for 2007.5 3500 Dually
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I'm wondering if the 3-ton capacity is enough, as the truck weighs closer to 4 tons, but I suppose if I'm only jacking up one corner, then that's only 25%.
Jack looks good. It won't let you lift more than it can handle.
As for jack points, at the rear, generally under the axle somewhere. One side or the other if you are just playin' with one side, or under the pig if you are playin' with both. (jackstands are a REALLY good idea too.) The problem with the trucks is, the frame is up there pretty high, and trying to lift on the frame, the jack just doesn't have enough lift height to be real useful there. Works OK in front, on a 2wd.....
