blue smoke
Old May 25, 2022 | 08:17 PM
Do your normal compression test. All plugs out, throttle held wide open, (fuel pump disabled.) Record the numbers. Then, run the same test again, but, before you test a cylinder, add a tablespoon of oil to it. See if the numbers jump.
Old Jul 9, 2022 | 12:39 PM
dsalak86's Avatar
dsalak86
the numbers where good for the compression test. Can it be the valve guide seals going out?
Old Jul 10, 2022 | 09:23 AM
Valve seals generally present themselves at startup. If you are getting constant blue smoke, you likely have a problem elsewhere.
Old Jul 10, 2022 | 05:25 PM
dsalak86's Avatar
dsalak86
Is it possible that valve cover gaskets can leak into manifold gasket’s???
QUOTE=HeyYou;3547041]Valve seals generally present themselves at startup. If you are getting constant blue smoke, you likely have a problem elsewhere.[/QUOTE]
Old Jul 10, 2022 | 05:37 PM
If they were, you would have other issues as well. Oil comes from valve guides, pcv system, or past the rings. That's why I suggested the dry/wet test. If the numbers jump significantly, rings are bad. I expect them to up some... but, if its more than around a 10 psi difference... rings are on their way out.
Old Jul 12, 2022 | 11:54 AM
10break's Avatar
10break
How do you disable the fuel pump on the 3rd gens with TIPMs? Just unplug the connector at the fuel pump?
Old Jul 12, 2022 | 11:57 AM
dsalak86's Avatar
dsalak86
I would pull the fuse to the fuel pump.
Old Jul 12, 2022 | 04:29 PM
10break's Avatar
10break
Thank you....son of a gun...I never noticed the one labeled "ignition switch feed" before.
