blue smoke
Old May 15, 2022 | 01:09 PM
dsalak86's Avatar
dsalak86
Default blue smoke
so right now i have the lovely "blue smoke" not as heavy but light. as i know blue smoke is valve seals going out. so i have talked to a mechanic and they say that if i changed the seals, it wont run properly and or still have blue smoke. is that true?
Old May 15, 2022 | 01:42 PM
Wonder where he got that from...... Fixing a problem should be exactly that, a fix. Not something that brings on other problems.....
That said, if you just get a puff of smoke at cold start, and that's about it, then valve seals *should* solve the problem. If the rings are getting loose though, may still have a problem.
What are you driving? Year? Engine? Etc. How many miles on it? How much oil are you going thru between changes?
Old May 15, 2022 | 05:54 PM
jrsick's Avatar
jrsick
All good questions by heyyou.
I'd first check the PCV. See if it rattles when you shake it.
Take a look at the spark plugs. That will tell you which cylinders are burning oil.
I rec next do a leakdown test. You'll know which cylinders are likely having problems based on spark plug condition.
Old May 15, 2022 | 06:28 PM
dsalak86's Avatar
dsalak86
2002 ram 1500 about 245,000 miles. The only time I get blue smoke when it’s warm operating temp.
Old May 16, 2022 | 03:27 AM
95RAM360's Avatar
95RAM360
what engine?
Old May 16, 2022 | 08:52 AM
dsalak86's Avatar
dsalak86
4.7 liter
Originally Posted by 95RAM360
what engine?
Old May 16, 2022 | 08:55 AM
Time for a compression test.
Old May 25, 2022 | 03:18 PM
dsalak86's Avatar
dsalak86
the compression for all 8 cylinders are good.
Old May 25, 2022 | 04:53 PM
Did you do a dry test, then a wet test? If so, did the numbers change significantly?
Old May 25, 2022 | 04:55 PM
dsalak86's Avatar
dsalak86
how you do a dry/wet test?
