Front axle replacement
Old May 31, 2022 | 03:03 AM
welch79's Avatar
welch79
Default Front axle replacement
A couple weeks ago I noticed I needed to replace the front U joints on both sides of my 04 ram 2500 4x4 5.7. So instead of just replacing the joints. I ordered the whole axle assembly for both sides. Everything went according to plan until I tightened up the axle nuts. When I tightened them the axle came out 1/4 inch on both sides. Now the axle doesn’t seat flush with the housing. Theirs a 1/4 inch gap there now. I kno tht can’t be normal so a little help would be much appreciated.
Old May 31, 2022 | 09:00 AM
Post a pic of the issue?
Old May 31, 2022 | 10:24 AM
welch79's Avatar
welch79
Old May 31, 2022 | 11:38 AM
I would think that so long as the axle nut is torqued to spec, should be ok.
Old May 31, 2022 | 11:02 PM
95RAM360's Avatar
95RAM360
You by chance measure the old axles and the new to verify they were same length?
also is the any “play” between knuckle and shaft?
