Hemi swap
Old Sep 11, 2022 | 11:44 PM
pedro.123456's Avatar
pedro.123456
Default Hemi swap
I swaped my 07ram with a 06 hemi wires in dash and motor it runs and drives now but my abs brake and air bag light are in every thing works at heat radio horn I’m trying to figure out why I have no codes I’ve only been able to find out that everyone says it’s a clock spring but I’ve replaced it any ideas ? Thank you
Old Sep 12, 2022 | 03:51 PM
If the lights are on, there should be codes. Need a fairly high zoot scanner to read ABS and SRS though.
Did you change the computer as well?
Old Sep 12, 2022 | 03:57 PM
pedro.123456
yea I changed the ecu and got it flashed for my vin and oh ok I’ll see if I can get the codes read I have a scanner but it says no codes but I’ll get my buddy to scan it with his snap on modes I think any idea what it could be tho ?
Old Sep 12, 2022 | 04:07 PM
Too many possibilities to list. But, you already dealt with what was my first thought... vin mismatch.
Old Sep 12, 2022 | 04:26 PM
pedro.123456
Oh ok thank you yeah it would not run before I got it flashed and I will post the codes taht pop up and mabey you could help thank you
Old Sep 13, 2022 | 09:08 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Need to figure out why it wouldn't run before that, 06 & 07 1500 engines are identical (if it was a 1500 to 1500 swap). Should have been plug and play with your existing onboard elex (PCM and wiring). You're getting problems because each year there are harness and computer variations, i.e. you're running a 2007 computer in your 2006 architecture and your truck doesn't like it.
Old Oct 3, 2022 | 11:09 AM
pedro.123456
I read the codes woty a better scanner and I have a u1416 and in the air bag module and a c2202 in the abs model any ideas why ? Vin was flashed into the new ecu and everything else is the same all original components minus the wires for the swap all components have the same vin
Old Oct 3, 2022 | 11:26 AM
c2202 is a vin mismatch on the ABS module. u1416 is a weird one... no clue there.
Old Oct 3, 2022 | 02:23 PM
pedro.123456
any idea what it could be ? The ecu was flashed
Old Oct 3, 2022 | 02:46 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
You turned something straightforward into a sh!tshow electrical nightmare. U codes are module communication problems. As per any reference I have, U1416 doesn't exist for Mopar. You sure it isn't P1416?
You LITERALLY should have just dropped it in and hooked everything up and it would've been fine. That engine didn't need the donor electronics smh.
