“New” muffler exhaust flow direction
Old 11-11-2022, 02:26 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,212 Likes on 2,963 Posts
Did you measure the pipe on each end? Inlet should probably be smaller than outlet.
Assuming they are both listed as the same size, inlet will actually be larger.
Old 11-11-2022, 02:33 PM
Dodgevity's Avatar
Dodgevity
Dodgevity is offline
I'd think the inlet should fit inside the pipe coming from the manifold. Anyway, see the diagram I updated with. That should determine it.
Old 11-11-2022, 02:58 PM
HeyYou is offline
The inlet pipe should go inside the fitting of what it is plugging in to. At least, that's the way I was taught to do it. Theoretically, it's less likely to leak that way. (of course, we welded the pipes all the way around, so leaks simply weren't an issue in any event....)
Old 11-12-2022, 06:20 AM
Dodgevity's Avatar
Dodgevity
We agree on that. This is why I was guessing it would be smaller. Im talking the inlet size on the muffler itself, not what it connects to. In the same vein, the outlet should have the exhaust pipe inserted into it, so it would need to be larger.
Quick Reply: “New” muffler exhaust flow direction
