Smokes occasionally
Smokes occasionally
Just picked up a 04 ram 1500 slt with a 5.7 on 188k miles and noticed on idle after driving it smokes a little bit, let it sit for a day and start it up doesnt smoke. Noticed some condensation in the oil cap, any leads if this is a headgasket issue or something else? I read that the pcv valve has problems on these hemis? I dont smell coolant in the exhaust or on startup but not 100 percent for sure. Planning to change the oil because its due but just had a dakota blow a headgasket at 160k so wanna be sure its not that before i stick money into it. I dont have access to a compression tester. No loss of power nor misfires.
Parts search shows a PCV for a 2003 5.7 1500. It can't hurt to replace the PCV anyway, and it may fix your problem. The PCV is in there tight so you'll need pliers. You'll be able to tell right away if PCV is bad.
Head gaskets don't just blow. Head gasket failure is usually caused by an event such as an overheat.
2) Also... check the engine oil level, i have had overfilled engine oil on vehicle or two and they were smoking but drained the oil down to the full level and no more smoke.
3) I have also gotten rid of a smoking engine problem on at least two occasions by putting in a quart of MMO into the crank case, driven 25 miles, then parked it overnight, then ran the engine in the morning until engine was completely Hot then changed the engine oil AND Filter and no more engine smoke, cold start up or hot.
These are just my experiences on a few occasions in the past.
