2004 RAM HEMI 4x4 engine running strange/rough
Old Jan 23, 2023 | 10:41 AM
  #31
GrossmeisterB's Avatar
GrossmeisterB
I see, but I don't know what the wiring from these LPG emulators internally looks like, so maybe that is why the ECU doesn't recognize an error?
Old Jan 23, 2023 | 10:46 AM
  #32
That is entirely possible. I have no idea how the LPG system actually works... .as I have never had to play with one. Would it be overly difficult to completely bypass the LPG system, see if the problem goes away??
Old Jan 23, 2023 | 11:18 AM
  #33
GrossmeisterB
Basically it is a 2nd set of injectors with a seperate control unit. I already tried it and bypassed/shorted the emulators (they emulate the fuel injectors when on LPG) and pulled the fuse of the controller. But the wiring is still in between though.
Old Jan 23, 2023 | 11:29 AM
  #34
Yeah, try swapping injectors. That will at least tell you if the injector is at fault, or the wiring.
Old Jan 23, 2023 | 12:01 PM
  #35
GrossmeisterB
Yeah, I will try that for sure.
Will have some time on thursday, the plan is to:
change the other spark plugs now they arrived
swap the injectors 5 <-> 7
follow the whole wiring from the injectors to the ECU and check the wiring to the LPG emulators there
I already did renew (shrinking soldering connector) the wire from the ECU to injector #7, but it seems that this was not the cause.
I also have a leak down tester here, but haven't tried it on a big engine like that though. Will have to go into further reading how it works on a V8. Have been using it on an inline 4 only.
If all this fails I will take it to a shop though for better inspection with some Chrysler testers (there is a workshop who has been a Chrysler service department a while back).
Thank you again for your help!
I hope I can figure this out.
Old Jan 23, 2023 | 12:18 PM
  #36
Works the same way. Turn the cylinder you are testing to top dead center, in firing position, (both valves closed) and test away. On these engines, supposedly, "up to" 25% leakdown is 'acceptable'.....
Old Jan 23, 2023 | 02:53 PM
  #37
GrossmeisterB
Yeah, will try that or a compression test first maybe?
But I don't think it is something mechanical that is wrong. That would be present at all times, not only on petrol?
And I read a lot about broken lifters and stuff, but wouldn't that throw more codes? At the moment I don't have any code at all, the P0307 I had in the morning was gone when driving home.
Very odd really.
I still think it is some electrical problem, but I'll have to see...
Old Jan 23, 2023 | 06:53 PM
  #38
I think it's an electrical problem as well. If it were mechanical, what you were trying to burn wouldn't matter.
Old Jan 24, 2023 | 03:23 PM
  #39
GrossmeisterB
I will have a major go at it tomorrow when I can use a friends' workshop so my fingers won't freeze too fast.
Will replace the spark plugs, remove the injectors, check and clean them, check the whole injector wiring circuits and test it.
I hope that the problems will be solved then, but if they aren't I think I will have to remove the cam covers maybe.
Even though I can't think of any explanation at the moment why it would run different on LPG with a e.g. broken valve spring or worn cam lobe or broken lifter or something...
Old Jan 24, 2023 | 05:34 PM
  #40
I agree with ya, I really don't think this is a mechanical issue......
