Timing advance
Old Mar 30, 2023 | 03:20 PM
1971superman1012's Avatar
1971superman1012
Default Timing advance
I have a 2003 4.7 2wd Ram and I put a new timing kit in the engine and now it won't crank and my scanner is saying my timing advance is -64% and I don't know how to fix this I've bought new crankshaft /camshaft sensors all my marks are dead on point what else is tbere
Old Mar 30, 2023 | 03:24 PM
Won't crank, as in, the starter doesn't roll the engine over? Or won't fire, as in the starter rolls the engine, but the engine doesn't start?
Old Mar 30, 2023 | 03:34 PM
1971superman1012
It rolls the engine but won't start
Old Mar 30, 2023 | 03:36 PM
1971superman1012
Rolls over but won't start
Old Mar 30, 2023 | 03:38 PM
1971superman1012
Rolls over and gets fire but still wo t start
Old Mar 30, 2023 | 04:29 PM
Will it start with starting fluid?
Old Mar 30, 2023 | 07:33 PM
1971superman1012
No sir and it has plenty of pressure in the fuel line so I know fuel pumps working and the relay⁰.... I've got a cheap scanner that says timing advance is -64% is that what it should say
Old Mar 30, 2023 | 07:41 PM
1971superman1012
Old Mar 30, 2023 | 08:06 PM
Likely one of your sensors isn't plugged in, or has failed. If the engine ain't turnin', advance goes to default value. See what it says while the engine is cranking.
Old Mar 31, 2023 | 08:02 AM
jrsick's Avatar
jrsick
What components did your timing kit consist of?
Do you still have the old sensors? What brand sensors and plugs are you running?
Have you verified that you are getting spark?
