Passenger Side ABS Sensor
Old May 6, 2023 | 07:55 PM
MedicNathan's Avatar
MedicNathan
Default Passenger Side ABS Sensor
Does anyone have a picture of the routing for the passenger side ABS sensor wire loom?
Background: Last week I replaced the wheel bearing and CV axels in my 2005 1500 4x4. When I ordered the replacements I only checked the drivers side for the ABS sensor to confirm I had them equipped, but when I removed the passenger side the wheel hub had no sensor attached. Based on some other things with this truck it wouldn't surprise me if the previous owner put on the cheapest hub he could, and the passenger side did look like an aftermarket brand. I cant find the sensor connector on the passenger side, but it is present on the drivers side.
Old May 6, 2023 | 08:02 PM
That may be correct. If your ABS lite isn't on, its entirely possible you just have RWAL, in which case, the passenger side won't have a speed sensor. The drivers side does, as that is where the PCM gets vehicle speed info for the speedo, and cruise control.
