03 transmission swap
Old Jun 26, 2023 | 09:18 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Originally Posted by Prismatic
I wonder how seamless that modification is. I assume I'd have to get the PCM reprogrammed from Auto to Manual to avoid any issues with a missing TCM...
Do I go forward with the 03->05 PCM swap and then convert later to the 8hp90?
Do I sell the damn thing, find a cummins and swap an allison in behind it?
Yes you would, or you can just ground pin #4 in the RFE connector.
Up to you, though you wouldn't be doing an 8HP70 or 90 swap; you have a 4x4. Unless you're willing to drop to a 2wd, you're going with an 8HP75 from a Ram. 8HP95 is what the Hellcat Durango and Trackhawk use; you're not gonna need the ability to handle 650+ ft/lbs to all 4 wheels.
Up to you, but how does commiefornia feel about trans swaps?
Old Jun 27, 2023 | 12:22 AM
Prismatic's Avatar
Prismatic
We don't have inspections, just emissions. As long as emissions are good they don't give a **** if it has all the wheels and tires or not
