Weird Piston Damage
Old Sep 19, 2023 | 09:37 PM
Undergrad35's Avatar
Undergrad35
Default Weird Piston Damage
I bought a 2008 Ram 1500, the engine was knocking bad.
Bought a used motor , installed it and it had a slight misfire. Idles smooth, but put it in gear, there is a misfire. Scan says misfire on #1 cylinder. Disconnect coil and misfire is noticeable by %100.
Did a compression test, 45psi, did a wet test and compression went to 100 psi.
I pulled the head and there is a big chunk of piston missing above wrist pin. Valves have not been touched.
On the head on both dudes of valves the head is chewed up.
Any ideas on the problem?
Cylinder with chunk out of piston.
Cylinder head showing damage opposite valves
Old Sep 20, 2023 | 02:30 AM
Prismatic's Avatar
Prismatic
Detonation, broken ring lands. Ran super lean.
Old Sep 20, 2023 | 11:40 AM
Undergrad35
What would cause the lands to break or the detonation?
Old Sep 21, 2023 | 08:57 AM
jrsick's Avatar
jrsick
That cylinder wall is pitted and rusty. Ring could have snagged on a rough spot.
Old Sep 21, 2023 | 08:01 PM
Undergrad35
PossibleI, I was entertaining the idea that a connecting stretched. But the valves didn't get touched.
strangely enough, the broken piston pieces didn't touch the valves either
Old Sep 22, 2023 | 06:52 AM
That had to make one heck of a racket......
Old Sep 22, 2023 | 07:50 AM
Dodgevity's Avatar
Dodgevity
So this used motor, was that from a private seller? Seems unscrupulous.
Old Sep 22, 2023 | 12:14 PM
fj5gtx's Avatar
fj5gtx
I'm thinking what you're seeing is the reflection of the top of the piston.
Old Sep 22, 2023 | 12:22 PM
fj5gtx's Avatar
fj5gtx
If you didn't trade in your original knocking engine, might be able to get one good piston out of that one and get back on the road. Have the head checked though, due to piston pieces pounding it.
Old Sep 22, 2023 | 02:34 PM
Undergrad35
Not at all when I got it. My buddy and I installed it, fired it up, lifters clacked till they got primed up and it ran smooth.
Then you put your foot on brake pedal and put in gear you could feel the misfire. But put it back in park, disconnect coil definate misfire, plug coil back in ran smooth.
That's when we did dry and wet compression test. Compression jumped up. So this happened before I got the motor for sure.
